An earlier post by andyinscotland highlighted the same problem as I have had with an old floor standing oil boiler - Boulter Camray Combi 1994 year. Basically we have central heating but a small amount of hot water and then nothing. Despite suspecting the boilers TMV I have had 3 plumbers out to assess the problem. Only one said it might be the TMV with others suggesting a replacement which including fitting is circa £3k. I know the boiler is old, corroded and may well need replacing but I have been surprised at the different opinions as well as the cost for replacement.
We have not had hot water for two weeks (other than the kettle) and things are becomming desperate. In order to try and rule out the TMV I have unscrewed the adjustable knob and taken out the spring and needle valve thingy from the TMV. I cleaned off the small amount of limescale and replaced the parts but still no change. I enquired as to the cost for a new one which is around £98 for the part. Yesterday I had a thought that if I left the stat (I mean the spring and needle valve part which expands with the heat - sorry don't know correct name) off and replaced the cap then the mixer valve should allow maximum hot and cold through together although this would not be limited to the factory 60 degrees max.
I tested the theory and yes we now have hot running water - luxury. I am aware that the TMV is there to regulate the hot water temperature coming through but we have mixer taps in the house and a mixer valve on the shower.
Whilst we are waiting for another quote for a new boiler I wondered if this set up is acceptable as a short term measure. My concerns are that if the hot water being circulated is much hotter than usual will it damage anything in the pipework or fittings.
I am now wondering whether to pay the £100 for a new TMV and replace this myself or go for broke and get a new boiler which will give peace of mind during winter and I'm sure be much more efficient and reliable in the long run.
Many thanks
Many thanks
