oil boiler trianco125 utility
7 Dec 2010
Newcastle upon Tyne
Hello could someone offer me some advice, was called out to a oil boiler not working, the property had a power cut and when the power was put back on the boiler would not fire up, i have checked the pump and oil and everything is fine i cleaned the photo cell and checked the nozzle, when i turned the boiler on the fan comes on also sparks but there is no ignition which led me to think it was the control box but the boiler does not lock out it just keeps on trying to fire, I still think it might be something else, could someone offer me some suggestion, many thanks. :mrgreen:
Could also be the oil solenoid coil failed, coincidentally.
Which burner is it?
Is there wetness on the blast tube?
Does the burner actually light and then extinguish?
Chances are that the baffles and flueways are sooted up, restricting the air that the burner can get in.
