Oil Boiler
7 Jan 2011
North
Ireland
Hi
My current setup is 35 sec oil for my heating system.
Was wanting to change it to 28 Home heating oil as I am changing my old metal oil tank to a 1300 ltr green plastic one.
The delivery man says all that is required is the oil burner nozzle changed, is this correct?
Don't want to cost an arm and a leg.
thanks
New nozzle, reset pump pressure and combustion analysis, bleed through oil supply and clean/change filters depending what is fitted. You need an oil pressure gauge, and flue gas analyser to do the job properly, but it would be prudent to have the boiler cleaned and the burner serviced at the same time.
So really would only cost me a service with the new nozzle installed first?
