- Joined
- 13 Feb 2021
- Messages
- 23
- Reaction score
- 0
- Country
My Dad has a fairly old Ecoflam Minor 1 Burner around 20 years old. Serviced last October
New pump fitted and set up, all cleaned and adjusted and running fine.
Just before Christmas he called to say the heating had not come on so i popped round and found it locked out. Checked oil (Half Tank) oil reaching pump, bled ok (No Air lock)
Pushed the re start and it fired straight away and ran perfect again.
since Christmas this has happened again a few times but always ONLY after a timed start.
If we leave the heating on continuous, it works fine. Cutting in and out as the temp reaches the set thermostat settings.
I have then set his next timed event (ie switch on 6am )the next morning, the heating pump comes on but the burner does not fire up. If i then push the Red button, it cycles through pre ignition but NEVER starts on the first push. I wait for 45 seconds and try again, it cycles through and after a few seconds, the solenoid clicks and it starts and runs perfectly until the timed session finishes. It Always starts second push, never on the first ....
Any ideas would be appreciated.
TIA
TIA
