We have an oil combi that works our hot water system. the most upper radiator is the towel rail in our bedroom. This towel rail is faulty and I need to change the valve and t connection to the electric feed.
Is it as easy as turning off the boiler and draining down, changing the faulty valves and t connection and refilling?
Do I need to drain down thw whole system or just enough to work on the towel rail?
