Oil Filled radiator Help!!!!
20 Sep 2010
Kent
My wife came home with an oil filled radiator, now.......we live in an old place that has ancient wiring, still have a wired fuse box for example.
I know there are strict rules for electricity in the bathroom, now I want to know if it can be wired off the lighting circuit, or does it need a dedicated supply.
Any help would be gratefully received
I wouldn't do it like that, what KW rating is it?
Either a dedicated supply or a supply off a socket circuit is more normal, saying that it opens a can of worms if you don't have RCD protection of all circuits in the bathroom. Ideally you need an electrician to take a look.
Blimey that was quick!!
It says on the box 150 Watts 240v 50 Hz Can't see any KW rating, it does say it needs to be protected by a 30mA differential circuit breaker and that it should be connected to a fused connection unit incorporating contact separation in all poles.
I don't understand any of that so that is why I am asking here.
What make/model of radiator is it?
You have three challenges:
1. Is the radiator suitable for use in a bathroom? I just had a look at a couple on the web and they are not suitable.
2. Where will you power it from? A lighting circuit is VERY unlikely to be meaty enough for even a modest heater. Sockets are not allowed in bathrooms within 3metres of a bath/shower.
3. Wherever it is powered from will have to be RCD protected. Given the age of your installation, I wonder if you have RCD protection, at all.
It is a towel rail, where else would you put one ?
Could I not fit a RCD attachment to my old fashioned fuse board ?
Ah, thats a bit clearer.
You will need RCD protection on the feed for the radiator. It is possible to fit a RCD to the circuit, but not easily to a wired fusebox.
Usually the radiator would be powered from a socket circuit. Usually you would put a fused connector there with an RCD. Is there a suitable socket near the bathroom?
I have an RCD to one circuit in my fuse board now following an earlier electrical problem.
There is a kitchen separated by a small hallway with an available plug circuit.
Or would it be easier to take the radiator back and get a fan heater ?
Hi, if you want to heat the room quickly just for the duration of a bath or shower a wall mounted bathroom fan heater is the answer. It does not matter what you install it MUST be done properly.
Dimplex do a bathroom fan heater.
Regards,
DS
A RCD FCU
ae235
can be used. But this is not really a DIY job.
