Oil filled wall radiator
11 Sep 2007
Can't think exactly which area to post this in, hope that this is the 'right' place.
I need to replace an oil filled electric wall radiator that has gone faulty - can anyone recommend a decent slimline model that can be wall mounted and simply plugged into the nearest mains socket?
No ideas then?
If it helps, the one that I used to have was a nice slimline model, I just can't find any similar ones online.
Thanks, a good start. More expensive than I had imagined though I must admit. Thought they would only be about £70! :)
Ahhh, much better, thanks. :)
Probably need to use an extension lead with it as the mains cable looks a tad short AND the socket it plugs into will be about 3 feet to the left, but that's not a big deal.
Ta. :)
At that price (amazed how cheap that last one is) that looks like an option for me. It would save channeling the floor. It would also give an alternative heat source if the gas was cut off for repair or the boiler went wrong or whatever.
But are these oil / electric jobbies not expensive things to run?
Rollerball be interested to know why you use them? :)
