Changed the oil on this this afternoon. No problem really, but can someone tell me what is the correct order to replace the filter element please. Should you stick the filter in the engine with the little spiggoty thing down the requisite 'ole, and then screw the plastic housing on, or should you insert the filter in the plastic housing and then screw the whole lot on?
I did it the former way, filter in the engine first, as I couldn't get the spigot in the hole otherwise, or at least I couldn't be sure of it.
There seem to be two schools of thought out on the internet. As always.
Just as an aside, it is without a doubt the nastiest thing I have seen for a long time. It even beats the Honda 400 F special oil filter housing bolt with the 12mm bolt on a big thread, that used strip the hex off because it was so tight.
The Peugeot one has lots of plastic, and clippy things inside the filter to foil the removal of the element. It was done up so tight by the gorilla (dealer) who tightened it last, that I thought it had broken when it came undone.
I had to look twice to make sure I hadn't accidentally put the socket on the front hub nut or something!
