Oil fired boiler quote
26 Jun 2016
Hi
Can i have feedback on this quote ?
were in west wales
The quote includes parts and labour for 7 years assuming original installer services yearly
Supply one Grant 15/26 system boiler, flue and plume diverter, one 200 litre unvented hot water cylinder, Honeywell motorized
valves, twin channel time clock, wireless roomstat,fire valve,
paper element oil filter, magnetic filter for boiler,10 thermostatic
radiator valves,10 lockshield radiator valves,10 drian off cocks for radiators, chemical to clean old rads and chemical to
prevent further corrosion,pipework and fittings, fit all above
and power flush system and commision, make good roof where
existing flue pipe is. £4956.00
I've looked in the crystal ball and the tea leaves and can confirm it looks fine.
In fairness, without seeing the job, it's very difficult to tell if that's an accurate price or not.
No one on here can see access, pipe routes, current system etc, there are just too many variables.
Why not get a couple more prices and compare.
Only 2 zones would be considered a poor minimum nowadays.
Oil tank?
As far as cost, as said above, get more quotes.
Sounds cheap to me, maybe too cheap. I've just given someone an estimate of £5.9k+vat for a similar sort of job . Get a couple more estimates and compare. No idea where the seven years warranty is coming from, AFAIK all Grant warranties are either five or ten years, depending on the boiler model chosen (VortexBlue boilers have ten year warranties when fitted by a G-One installer)
