Hi
I have a Camray 5 boiler, 5 years old, which switches itself on irrespective of the electronic programmer settings EP2001. I actually took the programmer off the wall lat night and the boiler still fired up. Beneath the hot water tank are 3 valves. 2 honeywell valves , silver box type and a bigger grundfos one. Both the honeywell valves vibrate when either the CH or Hot water is swithched on at the programmer, so I assume they're working( What are the wee levers for on the valves) There was also a small leak before the HW valve, a loose connection which I tightened. Is the problem the programmer or a valve or something else. If you've not already guessed I'm a complete novice at this.
