Unscrew the nozzle at the tip. Sometimes a tiny piece of dirt lodges in there and reduces the pressure. After unscrewing the outer nut there is a little barrel inside, hold this up to the light and see if there is anything blocking it. If there is it will usually come out if you blow down it from the outlet side. If this doesn't shift it GENTLY clear it with a pin or give it a sharp tap on the floor/table to dislodge it.
If you are going to use any oil make sure it is a very light oil such as compressor oil, DO NOT use standard car/diesel oil, it is too thick.
As stated, if the seals are gone it will be cheaper to buy a new unit rather than get it repaired.
