Oil leak from nozzle
25 Mar 2006
Got to re visit a breakdown tomorrow.originally found oil to be leaking into combustion head and down to under controller box,fitted new nozzle with sealing compound as thread seemed a little loose,customer says its still leaking so it looks like its dripping out of nozzle,never had this prob b4 would it be the solenoid valve on oil pump not sealing correctly-new pump needed?
change the pump. you can get repair stem kits. but i just change pump.
it will cure it.
with the caveat that if its a ecoflam burner..........you may well have
sh£gged the threads ........ :LOL:
