I am fitting a new oil tank which will be 2.25 m below the burner. I was going to use 10mm o/d pipe but the tiger loop information says that 4mm i/d pipe would be sufficient and warns against using pipe with too large a diameter. Am I OK using 10mm (8.8mm i/d) or is it likely to cause problems, pipe run is 20 - 25 m?
