Water in the oil was told to me by one of the OFTEC registered I approached for a commissioning quote. Apparently this one gets a lot of call outs in winter to unfreeze pipes, which is the water in them freezing not the oil. Anyway my oil pipe run will be attached to the house so should be a little bit warmer I guess.
I'm surprised about the 6mm I though 10mm was the norm.
It is the norm. Mostly because the installers can't think for themselves or read the oftec document which tells them that 6mm will do for most situations. Also published by Titan on their leaflet.
Anyway HRM wallstar manual say 10mm in the oil supply diagram so I guess I need 10mm. HRM supply all the fittings so I assume they are 10mm too. I wonder if they are olive or flared? Do you know?
They do supply 10mm, because all the installers (who don't think) give them grief if they don't. There's also the problems with most plumbing suppliers. They don't supply things because people wan't them, they sell them because they often are in bed with the manufacturers. You are only an end user, you count for less than I do.
They are compression fittings. If the equipment is installed by an oftec technician, they should use flares. There's no argument about this, that's it!!
OFTEC say used flared but installers I've contacted says that olives are the norm.
They can say what they like, oftec do try to get it over to them, but it's a hard slog. There are a lot of intransigent installers around, probably because they work on gas where compression fittings are acceptable.
Let them put the boiler in, and when theyve finished write to oftec. They might well visit the installer and tell them to change the fittings at their cost. They will probably not install a remote operated fire valve either, saying HRM don't supply one. Tough, if they're oftec registered they MUST fit one (they have to anyway to comply with building regs, but I have seen installations without, signed off by building control officers, 'cos they can.
[/quote]
