strange issue
i have some toolstation blank butt hinges, i replaced on all the doors last year
one door made a small squeaking noise , so i put a bit of 3-1 with PTFE oil on them and now the noise has increased significantly - i then tried GT40 , no change , some cooking oil , no change
sounds like the door is rubbing against the wood work - i had this on one of the door and had to readjust , but that was immediately i replaced the hinges
i cannot see anywhere where thats an issue here , a small gap all the way down the door as it closes, last night i used a torch to check the gap as well , in case i was going made
before i take the door off and investigate , i wondered if anyone has experienced issues with the hinges.
thanks
![www.toolstation.com](https://cdn.aws.toolstation.com/images/141020-UK/250/17464.jpg)
thanks
