Oiled oak flooring
18 Feb 2006
Birmingham
Hi all
I have 18mm solid oak planks laid down in my lounge. They have an oiled finish and has been down 3-4years.
Now I was wondering how offer I need to re-oil the floor?
There are some scratches caused by chair legs (even with felt pads), which I want to round off by sanding them down with a fine grit sandpaper, but thought I should do this at same time as reoiling.any commend on period of retreatmeant and what to use
Before you start sanding and oiling (you need to sand before your re-oil your floor) why not try some maintenance first?
Every wood floor needs a bit of TLC once in a while (say every 5 - 6 months_ to keep the wear and tear layer healthy and protective against dirt and spillages.
