Hey all,
I know there's been several posts about this before, mainly on the 18/25 boilers from what i've read. But I've got an issue with my boiler producing an oily smell..
When I purchased the house in July 2024, there was a huge issue with an oily smell from the boiler room. It was tracking up into the bedroom above the utility too. We've since had an engineer out who identified a leak on the fuel line that comes up from the ground into the boiler. It was leaking from the joint and tracking back down around the pipe and sitting there. That's been fixed, and there has been an absolutely massive difference. No longer any smells in the bedroom above etc.
HOWEVER I am still noticing when the boiler has been runnning sometimes I get a few whiffs of unburnt oil. Unfortunately where the boiler is, it's not blocked off from the house in any way, it's down a long utility hallway and then around a wall, without a door. So this smell carries through the house sometimes.
I've had the engineer out again, I watched him take the whole thing apart, took the pump off, checked all the joints to the pump, no weeping anywhere.. So I'm at a loss as to what it could be. He's also checked the flue (balanced) and combustion, everythings firing right and the quality of air in/out is spot on.
At this point, it's a very low smell and I could be being abit pedantic but I notice it sometimes and also when we have visitors I ask them if they can smell the oil when they walk in the house, to which the answer is always "abit yeah".
Side note: If I stick my head in the top of the boiler, the front (pump side) has absolutely no smell at all. However the back i'm picking up a slight unburned fumey smell (not exhaust smell).
I'm wondering if I should just block the area off with a door to make it isolated, but I feel liek that's just masking it rather than fixing it.
Any idea's would be welcome!
