I've fitted a new toilet and connected it up, via a couple of feet of plastic pipe and an adaptor, to an old clay foul pipe. The floor round the toilet and the floor over the new pipe leading up to the clay pipe has now been tiled.
The clay pipe is in two sections a straight section about six inches long that connects to a right angled bend that goes down through a concrete floor. This whole section of clay pipe is supported from beneath by a layer of concrete about three inches thick.
The bad news is a that after about three days of using this toilet a damp patch has appeared where the two sections of clay pipe join.
Due to the tiling and the joists this whole are is extremely difficult to get at and I'm frightened to death anyway of trying to open the leaking joint as I'll only probably break the clay pipe and end up with even more problems. The concrete under the pipe also make this difficult as the pipe is 'sitting' in it.
The leak is not severe, like I said its only a damp patch but there is no way that I'm going to leave it and tile over the whole thing.
So here's the long shot - it there any chemical I could use to seal this from the inside? Anything I could pour down the toilet?
Any advice gratefully accepted.
