I'm about to install a new electric oven (AEG B2100-4). The rating on the oven itself is 3.0kw, which by my calculations would draw about 13A.
The manual specifies connection via: "Cooker Control Circuit, 2.5mm2 PVC T&E, fuse - min:15A max:20A". It also says "It is necessary that you install a double pole swtich between the oven and the electrical supply with a minimum gap of 3mm between the switch contacts"
I plan to use this switch which although being overkill on the current rating, is the neatest Logic Plus switch with a 3mm gap that I can find.
What worries me a little is the fuse specification. The oven is to be installed on the cooker radial, which currently has a 30A fuse in the CCU. To meet with the manual's "15-20A" requirement, I guess this involves using a lower rated fuse in the CCU. The radial also feeds the cooker hood (through a 5A fuse) and the hob ignition (through a 3A fuse). So I guess I would like reassurance that replacing the 30A CCU fuse with a 20A will be a safe and compliant way to protect this circuit.
Thanks in advance.
Thanks in advance.
