Hi All,
I've recently noticed that my upstairs rads get quite warm even when the heating is turned off but when the hot water is turned on.
A bit of research tells me that this is likely to be a sticky check valve in the radiator circuit.
The system is quite old but works very well normally, hot water is gravity fed, no two-way valve at all and the rads employ a Grundfoss pump for circulation. The boiler is an Ideal Concord W WRS 255A which I'm guessing is around 30 years old.
I had a gas fitter out to quote me for a replacement boiler about 2yrs ago and he quoted me a large figure but said "to be honest mate it'll probably last for another 30 years so it's not really necessary", so I didn't bother.
So my question is what would I be looking for and where when trying to locate this 'check valve'? - would it be inside the boiler casing behind the flap that covers the controls and pump? What would it look like?
I'm wondering if giving it a gentle tap might free it up inside, otherwise I guess will need to drain down and replace it.
