Kitchen is being redone there's already a free standing electric oven and hob that's being binned and the new oven being moved 2m, new oven says 5.1kw total, not sure yet what electric hob is.
Oven is http://www.ikea.com/ms/en_GB/pdf/kitchen_instructions/framtid_dov8_2_double_iu.pdf
Old cooker has cooker isolator and cooker connection point. Unsure cable diameter yet.
Electrician says connect hob to cooker outlet then extend the cable over to the oven?
This to me doesn't sound right, for a start if the isolator does have 6mm and he puts another in the terminal needs to be 12mm?
If the oven is 5.1kw and the hob is say 6kw, 46A?
I'm thinking oven needs to be run back to CU with it's own RCD/MCB?
It's a bit late and it's bucketing down to go to the garage to check the RCD/MCB rating but I know it has it's own.
What do we think?
What do we think?
