have looked through previous posts and can't find anything exactly like mine so would like to make sure.if you can please help i'd be most grateful.
Have a schupa box with a 63A,30mA rccb, controlling 1no 30a,1no 20a, 1no 16a,and 1no6a,mcb's.
the 16a mcb is for a feed to the garage some 27metres long through the ceiling void and eventually out into the open, non conduited, to the garage.
I've been fitting the bathroom and kitchen at the property and asked why this particular mcb was always off.-- it seems that after some builders were working in the upstairs flat some time ago, also owned by my client, the mcb tripped and couldn't be put back on.
I cannot get to the cable now without ripping down the ceiling, as i beleive on looking at a part of the upstairs ceiling void there are a few nails protruding through the floor to no purpose.
i beleive they punctured the cable, and would like to replace, but the cable is so tightly jammed into the slots in the timber i won't be able to run another through by pulling the old one.
My other option is to run a cable externally from the c.u. along the sidewall of the house to the garage.
at present it runs to some bad shape sockets in there, which i'd like to replace with a shed c.u.,powering a light and a socket mcb, with one new socket.
here's my question at last.
what cable do i use--- it appears 4mm swa is talked of previously!
i would like to have some protection in the garage as the tenant of the garage might not be the same as the tenant of the downstairs flat. What could i install to ensure this if possible.
thanks for looking at this.
