The house I'm buying has a detached garage at the bottom of the garden.
Its constructed from a wooden frame, sitting atop a concrete base. The roof is made from corrugated asbestos cement, and has been clad with stainless steel around the outside.
I need the garage, but the surveyor has recommended that the asbestos has been holding water, and may now be unsafe, so it has to go. My local council will accept them at the tip, so I can dispose of it safely. I don't want to keep the corrugated cladding either, so I'll get rid of that.
This leaves me with a timber frame. What I'd thought of doing, was cladding in shiplap or loglap. The problem is, the garage has been dig into the ground, as the garden slopes up slightly, so the back of the garage is approx 2 feet below ground level. Will this cause damp? The other problem, the garage leads out to a lane. There is a brick wall bordeing the lane and garden, which is approx 7 feet high, but only single brick thicknes with no peers. Its starting to bow outward (the mortar has deteriorated too. The garage doesn't actually attach to the wall, so it's got a bit of a gap between the first sheet and the brick wall. This means that the roof is about 6 inches back from the wall, letting in a load of rain. What can I do to make it more water tight?
Or should I just knock the whole lot down and get a compton?
Cheers
Dave
Cheers
Dave
