Hi all,
I'm just after a bit of advice re plastering rooms in our house.
One of teh ares we would liek to do first is probably our bedroom which for some reason has been covered all over in that bobbly horrible artex
The main walls in the house are solid walls ( no cavity ). The walls at the moment are what seem to be all plaster ( no drywalls ) and i can imagine some of it may need chipping right back to the brick.
Is there anything i can do that would make this job cheaper? Prep work?
How do i know if the walls will need everything coming off and starting again from the brick, or if they can just be skimmed?
If they can just be skimmed, i presume the artex would need to come off? Is that something i can do easily?
If i was to do any prep work would skirting boards and picture rails need to come off or do they get left in place?
If all old plaster needs to come off would it be better dry lining the walls and skimming or still using the old method of rouch plaster then skim? and is one more cost effective than the other?
Many thanks
Many thanks
