Old Potterton Housewarmer 55 Pilot Light.
31 Aug 2013
Lancashire
Model:- GC 44 590 19
Hello, I seem to have a issue with the pilot light. The pilot light, lights but the igniter still carrys on firing like it has not detected that its lit. Will this be a oxy pilot unit fault. I don't know exactly how the boiler knows how its lit in the first place ?.
Picture of oxy pilot looks like this : -
You really need a RGI for this, it sounds like the control board is faulty but it needs to be checked out.
You won't receive any gas related diy advice on this open forum.
The lead performs 2 functions.
Fixed, No more replys need. No PCB was required, but that is exactly what my Gas Safe Register / Corgi Guy Said, good job I did not have it fit.
Why do I get the feeling that the pilot unit has been replaced, hope it was your GSR chap that did it?
Well all that was required was to Blow out the vent hole In the Oxy Pilot, with some computer compressed air. Which required no disassemble at all. Again GSR has left me with no confindence for the second time. A company Wanting to charge for a PCB Board, and would of probably cleaned out the pilot at the same time.
The last Time 2 year ago, I had fire serviced, by a different company, then next door had an issue with there fire, and carbon monoxide was leaking through our shared chimney stack. Lucky I had a monoxide tester. An inspector came out and told us the Company had failed to notice the the gas meter pipe was not sleeved through the wall and vents in living room was blocked and my gas was turned off & sealed, until repairs was carried out.
