hi folks,
i have a 1930s houe with cast iron drains
main drain seems to be ok, it's the smaller rainwater drain to the rear of the house that is blocked. The kitchen sink drains into it (I know you don't mix rain & foul nowadays but that the way it was done then..)
problem is the rodding point made from cast iron is totally rusted. It looks like its never been removed and the bolts / screws are just a rusty bump.
I tried with a hammer and chisel to clean them up to turn but not happening.
What's the best way to remove the cover?
drill out the screws? grind off the heads? or what?
Can I smash it off and buy a new cover that will fit or if i break it will i need to replace the whole section (which is half buried in concrete so not a good option if i can rod it and clean it ok)
thanks!!
thanks!!
