Hello everyone!
I'm looking for some help regarding a slate dpc.
My girlfriend's ground floor flat is an an old converted house with solid walls. She has had an ongoing damp problem which I investigated, and found what appears to be a slate damp proof course buried four inches below the ground surface (membrane with gravel laid over).
For a start, the slate sticks out from the brick wall by two or three inches in places all the way along. Is this how the wall would have been originally constructed, rather than cut the slate off flush with the brickwork?
I have exposed the slate and cleared the earth away from it. I'm guessing it should be cleared to between four to six inches below the exposed slate level?
The ground appears to be built up all around the external walls of the building and covering the slate dpc. There is no evidence of any later injection dpc.
Is this slate layer the actual damp proof course for the building, and how far should I clear the earth from it, if it is?
Any help would be greatly appreciated.
Philip.
Philip.
