OLD TO NEW WIRING - 2 WAY LIGHT SWITCH
16 Apr 2014
Tyne and Wear
Hi everyone,
hoping someone can help me to fit two new 2 way light switches in my hall and living room.
Current set up is that I have a light switch with 2 switches in the hallway. One of these switches operates the hall light, and the other operates the living room light.
I have the same kind of light switch in the living room, one of these switches operates the living room light, and the other operates the landing light.
I'm changing the light switches only to put some new ones on, but not sure where the wires from the old switch (labelled A, A1, B, B1 etc) should connect to the new switch which just has L, L1 and L2.
I've attached a few diagrams of the existing wiring in the hall and living room. All I need to know is which wire on the old setup goes to the wires on the new set.
Thanks in advance for any words of advice!
View media item 82515 View media item 82514
My advice is:
1) Get a multimeter, as you should not be doing electrical work if you don't have one.
2) Learn how switches work, as without that fundamental knowledge you should not be doing electrical work.
3) By combining 1 & 2 identify which terminals are which on your switches and thus safely and competently do the work you've decided to do.
Alternatively just wait for one of the unprincipled and callously uncaring fools on this site to come along and encourage and support you in your desire to do electrical work on the basis of blindly following instructions to put-this-wire-in-that-hole without actually having a clue as to why.
To be a little more constructive and in answer to your questions
The old arrangement comprises 2 switches in the one module (switch A and switch B)
Consider switch A
The A terminal is equivalent to L on your new switch
The A1 terminal is equivalent to L1 on your new switch
The A2 terminal is equivalent to L2 on your new switch
The connections for the B switch are similar
If, when you wire it up you find the operation of a switch is "upside down" then simple swap over the relevant switch wire(s) from the L1 and L2 terminals
one other important point ... IF the new switches are metal ones, you must earth them by connecting the earth wire (with some green/yellow sleeving) from the cables to the earth terminal provided on the switch plate.
Kind Regards, John
There you go, OP - you didn't have to wait long for such a person to come along, did you.
Whilst doing your (1) and (2), as you suggest, are to be commended, neither nor both will permit one to fly solo and "safely and competently" do the job, if one has no knowledge of electrical fundamentals; so your offerings may be considered equally as "callously uncaring".
A proper stance would be to state : "An apparent lack of knowledge exposes you to lethal danger and we can only recommend that you seek the services of a competent electrical technician".
Thanks everyone for your helpful responses. Took note of all of them and the light switches are sorted and working fine. Particular thanks to Jackrae and JohnW for the practical advice.
1) Agreed - I should have added "and learn how to use it".
Equally?
Equally?
My advice was as equally unprincipled and uncaring as that which encouraged and supported someone to do electrical work on the basis of blindly following instructions to put-this-wire-in-that-hole without actually having a clue as to why?
You
