Currently got a single ceiling light with one on/off switch in a room.
I want to replace with 5 x Low Voltage downlights and 3 x Dimmer Switches (1 by door, 1 x either side of bed).
I've had a look at the existing on/off switch to replace with a dimmer and there is just 2 wires (red & black) and No Earth at all.
Q1: I would imagine that i would connect the Red to the Common & the Black to the L1 on the new dimmer by door ?
Q2: No idea what i'd need to run to the 2 x bedside switches.
Q3: Bearing in mind that there is only a Red & Black and No Earth, would i be better re-running the wiring so that i get an Earth connection - if so, what should a connect the earth to ? i.e. clamp to cold water pipe etc ?
Please help !
Thanks in a advance.
Please help !
