Is anyone able to help me with this problem.
I have an old Heating World wall mounted oil boiler which is regularly serviced and rarely used.
It was working fine then was switched off for a week.
It now ignites, runs half heartedly (it used to roar) then locks out after about 10 seconds.
Ive replaced the photocell, control box and oil pump.
Ive checked the oil pressure which runs as 10 bar and have tried to adjust the air flow.
Ive looked inside the combustion chamber. the nozzle looks fine and there does not appear to be any wear on the electrodes.
Ive also removed the baffles and cleaned out the chamber
If i take the photocell out and expose it to a lamp the burner keeps going even though its still not a roaring flame as it was before this problem occured. I can see the oil buring through the photocell mounting.
The inline filters are clean and clear.
The only unusual thing is some black oil in the Tiger Loop bowl but i'm not sure where this contamination comes from.
As it was working fine before this problem it has to be something benign but i can trace it.
Any suggestions where to look next please.
