Hello
I bought a Silverline olive puller from Toolstation. Previously I've hammered the olive and nut off, or used a hacksaw.
To use the pipe slice on 22mm there is an insert that goes into the pipe, which the puller bears against. I can't get this into the pipes because the slight rounding created by a pipe slice means the insert doesn't fit.
Is this a common problem?
bsr
bsr
