Hi all,
I am a DIY/ Novice plasterer. I have plastered 2 bedrooms so far (not ceilings) and the results have been better than I expected. The only problem I have is that I end up with some minor blemishes on the wall. I have good look at the wall when wet and I try to smooth out as much as I can before the plaster goes off, but I always end up with some blemishes when it dry's out. I use 2 coats of plaster from the same mix. That is I skim the wall and then using the same mix I skim over the first coat again. I find this gives me more time to smooth out and I also find it easier to get a flat smooth finish (except minor blemishes). Should I be using 2 coats? If so should I use 2 from the same mix or should I let the first coat dry out a little, say 20 mins or so and then mix up again and re-coat. The blemishes are not too bad and a little sanding gets them out but I want to get it as good as I possibly can.
I use multi finish plaster
Any advice would be great.
