One Cold Rad Upstairs, all other rads working fine. HELP!!!!
12 Nov 2005
Bath
Boiler : Worcester 240
Pressure : 1 Bar
Building : 2 Storey
Unsure when the problem started as the cold weather has just begun. Bedroom rad is stone cold but all others, including those on the same floor, are working fine. It did work before but no more! Both the inlet and outlet are cold as well. All rads have been bled upstairs but nothing works. Recently, we had the kitchen refitted but I don't think that has anything to do with it. Any help would be greatly appreciated.
Cheers :eek:
Either a stuck valve - especially if a trv, - check the pin springs up and down
or an airlock - close other rads which should make it work eventually.
...And if you've had the decorators in check the lockshield valve is open too, subject to proper load balancing (search "how to....balance a system")
Thanks for your swift replies. :D I will try out the tips today.
One more question however, which valve would I need to turn to up the pressure in the boiler.
It has slipped down to below 0.5.
Could this be the reason for my troubles?
I remember the guy who did our kitchen saying that the pressure should be at 2.
Does this sound correct??
yep, plenty food lots of cuddles, new shoes yesterday, all nice new flouresent gear and a leg light for riding in the dark , unlike some of the dikheads on bikes with no lights at all.
Could someone tell me how to check the pin springs on a TRV rad??
Cheers
Hi...you need to take the sensing head off the trv and push the small pin down. It should spring back up by itself. Or if its stuck down already you will be able to feel that its down as you push it. DON'T pull it up because on some trv,s the pin comes out and you get an unwelcome shower. Try tapping the side of the valve for a while if it is stuck, sometimes that will free them.
Just tried everything that has been suggested. Both inlet and outlet are freezing cold. Anymore suggestions?? This is driving me mad. Got a 10 wk old baby to keep warm :mad: Bless her little cotton socks. Can't understand seeing as it worked before. Any help will be greatly appreciated.
Cheers
SI
I whacked the vavle and hey presto it worked. Thanks to all you guys. Til the next time. Cheers
