One cold radiator.HELP
16 Sep 2004
All radiators fully functioning after summer except one. Have tried bleeding system no air appearing to cause problem. Was told by neighbour that if I remove rad.thermostat pin might be stuck in but can't figure out how to get thermostat off ( no obvious screws!) Please help or my toddler may freeze!! :( :eek: :cry:
Depending on what type of trv you have there should be a nut at the bottom, if its a honeywell etc it will be between the trv head and the brass valve, should only be finger tight so give it a go and you will be as right as ninepence
Your toddler will not freeze at this time of year unless you have him/her tied to the chimney stack half naked. Try a jumper.
cheers guys will give it a go!! thanks oilman must threaten him with that next time he misbehaves! :LOL:
