Can anyone help? This rad is driving me mad. it is downstairs and it will not heat up.
bled rad and it got warm but then started to cool down again.
there are three rads downstairs one in passage on in front room and the one that will not heat up is in backroom downstairs.
two rads upstairs - heat up fine. the rad in the bathroom is further away from the boiler and it heats up fine. The rad downstairs for some reason the water will not flow down to it.
took rad off and turned water on and opened up flow valve - pressure seemed okay. opened up return valve and the pressure seemed greater!
tried looking on the net and i cant find anything.
any help would be appreciated.
