I have one cold rad downstairs, all others are fine. The rad doesn't ever heat up even if i turn all the others off. The hot water tank is in the kitchen and the pump is under the floor in the living room.
I have read most of the messages relating to problems with central heating on this site and have tried many of the suggestions.
I shut off the inlet and outlet valves to take the rad off the wall but a small leak has now appeared just below the outlet valve. The water coming through is hot.
What do i do????
What do i do????
