- Joined
- 11 Nov 2008
- Messages
- 6
- Reaction score
- 0
- Country
I am trying to resolve a problem I have with the heated towel rail in my upstairs bathroom. All the radiators in the house seem to work fine except for this one. I can't get it to heat up! The problem started when we first switched the heating on after the summer.
I have a Baxi condensing combi in an old 30's semi. The towel rail will not heat at all, even the pipes leading to it do not seem to be warm.
If I bleed the towel rail so that the water is gushing out, it will eventually start to get hot, but as soon as I close the bleed screw it goes cold again.
I have seen other posts with similar problems but they often seem to be due to faulty TRVs. This towel rail has no TRV (as far as I can see) - it is a Hudson Reed Marquis and it has two valves/taps at the bottom - I'm not sure what these do? Sorry to sound a numpty - I am just a mum trying to get the bloomin' thing working again.
I have tried bleeding every radiator fromdownstairs upwards. I have also tried switching all rads off downstairs to see if it kickstarts something? No joy.
Any advice would be much appreciated.
