I have 12 rads.
An Oil Boiler.
All in a large bungalow which also has 2 X upstairs bedrooms and a bathroom ( derived from a loft conv )
My boiler has a dial ranging from 60 - 90.
To ( I think foolishly ) save Oil I set the boiler stat to 70 ( ish). This eventually caused the room stat which is in the hall to switch off the heating. When I say eventually I mean about 3 hours from very cold.
I then decided to up the boiler setting to 80, this caused the house to feel much warmer and more so warmer much faster.
My theory is that using a higher boiler setting will use more fuel whilst it's running but it will heat the house up much faster than at a lower setting, this equalling cheaper running costs ?. Since it takes over 3 hours for the room stat to reach the desired 22 - 24 c and then switch itself off, it's now doing it in half the time. This must be more efficient ?????.
I have just today changed 10 out of twelve rad valves to TRV's as the originals were standard valves, as because we have a coal fire in the lounge and when it's lit the room is over hot, I thought having TRV's would save wasting expensive fuel.
However as a result the whole place feels hotter.
And I feel sure it will save money. What do you think experts ?.
An Oil Boiler.
