Ok.... i had an extension to the house completed about a year ago. In the new bedroom (with a standard chipboard floor), i have one radiator on the outside facing wall. All is well with the extension and the size etc of the radiator. My problem is this :
When the builders drilled the holes in the chipboard floor (from underneath) they did so with a 15mm drill, which is the exact size of my pipework, a great fit you would think. It is, but ever time you walk in the room after a 15 min break or so the floor has ''bounced back'' and you hear an audible ''click'' as you put your weight on the floor area around the radiator and it's pipes.
Given the tight fit of the pipe work coming from the floor how can i stop this rather annoying sound..... i did think of using a drill and a very small drill bit to use 'gentle' drilling to dig out the surrounding floor around the pipework thus giving more room for the pipe to flex when you stand on the floor, needless to say this is worrying me given one slip of the drill and hey presto....
Any ideas much appreciated, and although this is no major problem and the builders did not know it would happen, after a year or so it is very annoying and i would like to try and solve it.
N.B I also did think of trying to ''lubricate'' the pipe by swamping the bottom of the pipe where it meets the floor with say wd40 or copper grease. Not to sure though.
Cheers.
Cheers.
