This is what my current situation is.
I have a 2 floor flat, Kitchen Bathroom and Living room on one floor and then above it my bedroom on the same floor plan as the living room. I have a Ideal Classic LXFF 230 Combi Boiler that supplies 4 radiators. one in each room. My bedroom radiator has never put out enough heat to fill the room (it was a designer radiator prolly not that efficient) so I replaced it today, with kudox double panel 7350btu drained the system fitted it in a different position and bled the system. Started it all back up and the 3 radiators down stairs get nice and hot but the bedroom stays stone cold all the way down to where the pipe enters the floor.
When I close all the other radiators off (ie at the theromstatic valve) the boiler shuts off and won't ignite. (as if in a safety shut off mode) When I open the other thermostatic valves it reignites and continues to heat the 3 downstairs rooms.
I hope this is clear and helps you give me advice...many thanks to all
Rob
Rob
