Our house has an old boiler and imperial rads and although it is all working well at the moment we thought it will eventually need replacement so would be a good idea to do it now before we redecorate and put in carpets and flooring (whole house needs doing)
A plumber came round yesterday and noticed we have a one pipe system, he has said we need to upgrade it to a two pipe return and feed. After doing a bit of research on the internet it would appear you don’t have to but the boiler will be less efficient if you don’t, most of the posts I found were a couple of years old so wasn’t sure if regs may have changed.
I haven’t really noticed any of the reported problems with a one pipe system our rads seem to heat up fine, but on the other hand if you put the hot water on three of the radiators also heat up which he said was odd.
What are the risks of leaving it as a one pipe and just getting a new boiler and rads installed. The cost is more than we were expecting but I don't want to have to go back in say 5 years to fix things.
