One radiator no working
20 Jan 2009
London
The radiator in one of our upstairs bedroom isn't working. I've bled the it so there's definitely water in there. The pipe leading to the radiator is piping hot and the valve is open, so I don't understand why the hot water isn't circulating. Any ideas?
I know it sounds stupid but have you made sure the lock valve is fully open on the other side??
how long has this not worked?
could be that although both valves appear to be open that one has stuck closed internally or is clogged up.
to check this, having turned both off, undo one from the radiator, stuffing a rag into the hole in the radiator to prevent too much water loss (have towels, saucepans, buckets around!!!) pull the valve forward and turn on slightly to check that water does flow out. Repeat for the other.
While you're feeling in the mood, drain the radiator out and take to the garden and flush out with a hose until it runs clear.
hope this helps
