One radiator not working when heating+hot water switched on
23 Jan 2022
I've got a problem with a radiator, and have done some searching around the forum and wiki, but not been able to find a solution to this specific issue, so would appreciate any pointers.
System boiler, unvented system. When I switch on the heating only, all radiators in the house heat up correctly. However, when I switch on the hot water + heating simultaneously, one particular radiator remains stone cold, but all other radiators heat up correctly, and the hot water heats up.
I've bled the radiator and checked that both valves are open (1x TRV), but the fact that it works when heating only is on, suggests there's some other reason why this isn't heating up.
The boiler is on the ground floor, and the radiator in question is in the same room as the boiler (open plan kitchen diner), but on the opposite wall. I'm not sure exactly of the layout of the pipes, but this radiator is neither the closest nor the furthest away from the boiler. Let me know if you need further details on the system.
Any suggestions on where I should be looking next, to diagnose this, would be much appreciated.
