Our central heating system is, I believe, a sealed pressurised system, all the pipe work is 15mm except one radiator in the hallway that has microbore pipe, had a BG engineer round recently and got chatting as we have had numerous issues with the far end of the house(actually a bungalow)rads not getting up to temp etc, he said that the rad with the microbore would be causing problems as it is restricting the flow...kind of makes sense but then why would any half-about plumber/heating engineer have fitted it in the first place and would we be better off getting it converted to 15mm?
I'm guessing this rad was an addition to the original system.
We're due to change the flooring in the hallway soon so if it needs doing, now would be a good time.
Any advice/thoughts much appreciated
