First, brief apologies for the simplicity...I'm a bit clueless when it comes to plumbing.
I live in a rented ground-floor apartment (so all the radiators on on the same level). Gas boiler (central heating only) is in the garage below.
We had our old boiler changed 3 months ago. Prior to this all radiators were working fine. Two weeks after the boiler was installed, a gas engineer came round to "switch it on" and do all the temperature settings. Since then, two of our three radiators work fine, but the bedroom radiator is stone-cold.
The bathroom radiator is almost directly above the boiler. In the garage, the pipes leading up to this radiator are clear to see. The radiator in the main room is, I guess, only a few metres away. This also works fine. The bedroom is further away again and is absolutely stone-cold. We had problems a few years back with this radiator which turned out to be a faulty pump, but we had sorted the problem, and it ran fine before the new boiler was installed.
Its a complicated situation as the company that installed the boiler say it is a radiator problem and will not come out to investigate (they are based in my landlord's hometown, one hour away). Equally, I'm not very diy orientated and am reluctant to tackle a big job myself. However, neither do I want to pay a fortune (even if we are reimboursed) for somebody to come out and open a valve or two!
Even though I'm sure there is no thermostatic valve on the radiator (its a simple open/close head) I did as the company suggested by phone, and tapped the inlet valve head lightly. Nothing. Valve is fully open. Bleeding the radiator did nothing (in fact, there was no air, just water). Very occasionally there is a tiny gurgle but nothing much. Inlet and outlet pipes are stone cold too. In the cupboard in the front room there are four copper pipes which run along the wall - I assume two for the radiator in the front room, two for the bedroom. Top two are hot, bottom two cold. These can be traced back into the garage, where the bottom two are still cold, even next to the boiler.
Any ideas?
Could the lockshield valve have been closed to change the boiler and not reopened? If so, why are the pipes cold all the way up to the boiler? More importantly, could it have caused any damage?
Is it possible that the pipes are not connected to the boiler properly? (I assume not and that somewhere the four pipes lead into two pipes - its not possible to see).
Could it be a pump problem, as before? Boiler doesn't seem to be noisy though.
Any other possibilities?
Many thanks...I'm getting tired of being told to tap the non-existant thermostatic valve!
Jinks
Any ideas?
Jinks
