Over the last approximately 15 years we have found it impossible to get all the rads to heat up without shutting off the rads in rooms not being used.2 years ago we had a new Glow worm Flexicom hx 24KW condensing boiler fitted the old one was a 50,00 btu so I thought all our problems would be over.Wrong we still couldnt heat all the rads.There is TRV's on all rads 9 in total there is no room stat or cylinder stat.The C/heating pump had to be changed last November.I have been told by a plumber that the original system was a one pipe system and the new rads have been piped as a two pipe and the rest has to be changed and a valve put between the flow and return.Can anyone advise me if this is the best option.He will be fitting a cylinder stat and another zone valve so I can have water only or C/heating only or both at once.Just one more bit of info the original cylinder was a primatic and when it needed changing I had a header tank fitted and an ordinary cylinder.
