Hi everyone,
I have a sealed central heating system. There is one towel rail that has never worked. There are two others exactly the same in other parts of the house that work fine...along with all the rest of the radiators. As I was having one downstairs radiator replaced I drained the system and decided to do some investigating on why this particular towel rail isn't working.
Symptoms:
After draining the system during the process of refilling the system, bleeding the towel rail resulted in plenty of air coming out of it and I could feel the flow pipe and the bottom of the towel rail getting hot (The heating wasn't on when I bled it, but it had been just prior).
It seemingly drained when I emptied the system but I don't know if drained through the flow or return (I guess its possible to drain through the flow if you are just draining the system). Hot water could get to it upon refilling the system, but isn't getting to it now the system has been completely refilled. The radiator is cold as are both flow and return pipes, even if the heating has been on for hours.
There is no thermostat on the radiator, so no TRV to worry about.
I have ensured both flow and return vales are full open.
Previous to all this i.e. before draining the system I had shut off all other radiators in the house and left this one open to try and force any blockage out. No luck.
I have bled it several times since and all that happens now is water is coming out and it doesn't get hot. Although I guess if I bled it for long enough some hot water might get through as it did upon refilling the system.
Any suggestions?
Symptoms:
Any suggestions?
