Hi folks, I have a IDEAL MINI HE C24 combi boiler. I have an issue of only having hot water while the central heating is on or if it has very recently been on.
I bled one of the radiators yesterday and had to top up the pressure as it fell to zero. I thought the higher pressure would sort the issue out (I can’t remember what the pressure was before I bled the radiator).
When the hot tap is turned on the boiler fires up and appears to work fine but i get no hot water. If I then flick the Heating on the tap become hot. I would understand the hot taps never getting hot but as they get hot with the heating on I’m a bit confused.
Anyone shed some light on the situation?
Thanks.
Thanks.
