i have just fitted 2 french doors in our extension. they are quite heavy, i have put 2 hinges on but should i be putting on a third?also i have a 6mm gap where they both meet in the middle,is this too much? i have not put any handles on yet.
I would be putting 3 100mm butt hinges on the doors especially as they are heavy doors.
The 6mm gap shouldnt be an issue but again,if you're taking the doors off again id pack the hinges over a bit.Cut some cardboard from a cereal packet and slip behind the hinges when you re-hang the doors.
