Open Circuits
18 Apr 2005
I have been informed that the ring main for my sockets is open circuit, could anyone tell me how to troubleshoot this problem and find the cause
Cheers
Cheers
check the back of every socket. look for a loose wire. be careful tho, if its old cable you could damage it if your too rough with it
Could be a socket terminal tightened up on to conductor insulation instead of on the copper core.
If your unlucky the opencircuit might be between socket outlets.
first thing you should find out is if live, neutral and earth are open. if yes, then likely a cut cable, not connected or all terminals came loose. if just 1 core, then look for loose cable. if nothin, it could be tightened onto the insulation
